Unnecessary Solid Infill?
Not_Dave
(@not_dave)
The slicer is adding a lot of unnecessary solid infill when slicing, I'm sure there is a setting to disable this but I can not for the life of me find it!
There should be a screenshot, it's the purple part that I don't need, it's adding a lot of print time and material wastage, it does not go away regardless of how many perimeters or infill I have.
any advice?
This topic was modified 5 years temu by Not_Dave
Opublikowany : 08/02/2021 6:47 pm
Clemens M.
(@clemens-m)
RE: Unnecessary Solid Infill?
Only showing your picture makes it unimpossible to give you an advice. You can save your project in Slicer as a 3MF-file. Than you ZIP that file and then you can attach it here. Having a nearer look to your parts and settings can lead to your problem solution.
Best regards, Clemens
Opublikowany : 08/02/2021 7:42 pm
Some of the purple is likely due to settings under Print Settings->Layer and perimeters->Quality.
  • Extra perimeters if needed
  • Ensure vertical shell thickness
  • Detect thin walls
These mostly deal with curved surfaces and are intended to help avoid gaps between extrusions in otherwise-thin walls. They can cause that sort of infill. Of course, turning them off may result in other issues in the print.
Opublikowany : 08/02/2021 7:47 pm
There's also this open issue on github which pertains to this https://github.com/prusa3d/PrusaSlicer/issues/1054
If you are lucky it appears that setting same number of layers  for top and bottom can on *some* models remove it but on others you are going to be out of luck.  At least until or if the issue is resolved.
Opublikowany : 08/02/2021 8:09 pm
emre
 emre
(@emre)
There Is But One Workaround
if your Layer Height : 0.2, make your Minimum Parameters : 3 then see the magic happening:) for 0.3 layer height use minimum 4 parameters. weird but this will cut your print time by a lot.
Opublikowany : 16/10/2021 7:18 pm
