Support interface layer in different material
Is there a way to print only the support interface layer with a different material by means of manual filament change on a MMU-less printer?
Best Answer by JoanTabb:
Have a look at
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/acting-as-my-own-mmu/#post-100907
and
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../simple-way-to-print-in-real-multi-color-without-mmu-or-layer-height-based-changes/
allocate the interface material extruder in Prusa slicer
RE: Support interface layer in different material
Have a look at
and
I found @joantabb's suggestion to be an efficient way to print multi-color/multi-material --- as long as you only have to swap filaments for a very small number of layers. More than that and it gets extremely tedious.
Thanks @joantabb, I had been looking at the multi extruder settings earlier but didn't think it would work with single extruder machines.
I've experienced that firsthand now during testing. Luckily I'm only looking to do this for a single layer at most, so not too much of a consideration here.
Have a look at
and
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../simple-way-to-print-in-real-multi-color-without-mmu-or-layer-height-based-changes/allocate the interface material extruder in Prusa slicer
Apologies for bumping such an old thread but this is exactly what I'm looking for. Before I spend any time on it can just the top interface layer be printed in a different filament using this method?
