Struggling with top layers despite 2 full days of testing
Earbud
(@earbud)
I'm struggling to calibrate my machine to Prusaslicer 2.7.1 It seems like these top layers and the overall result of this calibration cube is bad. I've read through hundreds of threads here and a lot of it has helped me progress (it was way worse when I started). Here's the working environment:
  • Slicer: Prusaslicer 2.7.1
  • Machine: Flashforge Adventurer 4 (with custom configuration bundle to make it work in Prusaslicer)
  • Material: eSUN Matte black ePLA
  • Nozzle: 0.4mm
  • Nozzle temp: 210 deg C
  • Bed temp: 50 deg C
Attachment: Visual method calibration cube (please see attached ZIP of the 3MF & STL file)
Details of this print:
  1. Bottom layer fill pattern = Octagram Spiral (it looks great and prints well).
  2. Top layer fill pattern = Monotonic (It doesn't look great at all and doesn't print well).
  3. Fill pattern is cubic with 50% fill density (to support top layers and to avoid them sagging).
  4. First few layers print perfectly. Eventually though, as you see in the pictures, there is either a layer shift or a height or temperature issue that occurs and you see some layer shifting (I think that's what it's called).
  5. I print on painter's tape; it gives amazing adhesion. Out of 10 prints, up to 4 of them fail because of bad adhesion. I don't like using glue stick, it's messy. I also don't like changing first layer height to something higher because it causes elephant foot and when I compensate for that it reduces the extrusion thickness, so I figured I'm just going to leave it at 0.2mm first layer height.
  6. I use 5 top layers but it still looks bad.
That's all I can think of. I'm happy to provide more detail if required. Below are the pictures of the current state of this print. Thanks for the help 🙂
Here's the ZIP file: visual-method-cube
Napsal : 17/02/2024 9:04 pm
RE: Struggling with top layers despite 2 full days of testing
Hi Earbud,
|From a distance,
It looks like the top layers are wiggly lines where they should be straight, and it looks like the sides are being distorted.
Is it possible that the extruder is over extruding, and putting too much plastic into too little space?
Could you try re slicing the model with an extrusion multiplier of say 0.90 and re print, see what the model looks like just for a test??
Napsal : 17/02/2024 9:58 pm
Earbud
(@earbud)
Hi Joann,
Ta for the response.
Sure, I'll set the extrusion multiplier to 0.90 as you suggested and upload an image of the result.
Napsal : 17/02/2024 10:19 pm
SUper, I am just looking for a difference in surface finish at this time
Napsal : 17/02/2024 11:07 pm
Earbud
(@earbud)
It's okay, I understand. It's not like anything is going to go horribly wrong. I'm on the forum for the exact purpose of learning from others, so I'm willing to try things.
Napsal : 17/02/2024 11:17 pm
cheers.  please be aware that I am UP Based. so may not be in the same time zone as you.
i am actually in bed preparing for sleep now, so my response cycle may be out of sync.
Napsal : 17/02/2024 11:57 pm
