Some parts disappear after slicing
enzo
 enzo
(@enzo)
Hi, please anyone can explain me where I'm wrong?
My .STL has a couple walls inside the central box as you can see in the image I attached. They disappear after slicing.
Moreover the 3 square holes I designed in the same box become a single square hole!
I browsed all the settings but can't see any of them which could cause this.
Please help! Thanks in advance.
Best Answer by karl-herbert:
Posted by: @enzo
Hello and welcome to the Prusaforum!
If you would share an STL file with us, we could test this. I suspect that there is an error in the STL file.
wbr,
Karl
Postato : 13/06/2021 12:04 am
Swiss_Cheese
(@swiss_cheese)
RE: Some parts disappear after slicing
you most likely have open edges in your models design creating a non-manifold situation and slicer is doing the best it can to fix the poorly constructed model, I don't use open scadd but I believe its one of the programs that creates such errors.
The Filament Whisperer
Postato : 13/06/2021 4:52 am
Posted by: @enzo
wbr,
Karl
Postato : 13/06/2021 10:43 am
enzo
 enzo
(@enzo)
Please, can you tell how can I attach a .STL file? The "Add media" doesn't allow me to attach  "for security reason".
Thanks.
Postato : 13/06/2021 12:25 pm
If you save the project as a 3mf file, zip it and upload it here, we'll see not just the STL but also all your settings.
Most likely the STL is broken. Another common source of artifacts is thin walls but these walls don't look very thin to me. Just in case you can try to slice with Detect thin walls turned on.
Postato : 13/06/2021 2:57 pm
enzo hanno apprezzato
enzo
 enzo
(@enzo)
@fuchsr
Timer_display_support_210611
Here it is.
Postato : 13/06/2021 3:36 pm
enzo
 enzo
(@enzo)
@fuchsr
I sliced both with "Detect thin walls" on and off but the result is the same.
Postato : 13/06/2021 3:45 pm
enzo
 enzo
(@enzo)
@karl-herbert
I solved it by repairing the .STL with the "repair" function in the "File" menu.
Thanks for the hint to everyone.
Postato : 18/06/2021 8:42 pm
