Slicing: Gap in narrow cone when slicing temperature tower
McFly
(@mcfly)
Hello!
I want to print a temperature tower, but I've got a problem with small cones that are integrated into the tower. There seem to be "floating" pieces at the top of the cones:
Is there a way to prevent these gaps?
I'm using the PrusaSlicer version 2.5.0 on Windows 64-bit.
Thank you in advance!
I've attached the project file with the tower and the problem as a ZIP file: SmartTemperatureTower_Stand 220-185.zip
Best Answer by Neophyl:
Change the slicing engine from Arachne back to Classic.  The current default arachne settings have problems with some models including this one.
Print Settings>Layers & Perimeters>Advanced>Perimeter Generator.  Its a yellow setting so you must be in Advanced/Expert mode to see it.
Napsal : 05/11/2022 12:07 pm
RE: Slicing: Gap in narrow cone when slicing temperature tower
Napsal : 05/11/2022 12:38 pm
McFly
(@mcfly)
That fixed the problem. Thank you very much!
Napsal : 05/11/2022 6:06 pm
