Set external walls to be 0.1mm and infilt to 0.2mm ?
Vido
 Vido
(@vido)
I looked up on internet and I searched in Prüša Slicer but I could not find this option
so basically I want outer layer of object to be 0.1mm so to do 2 passes and infill layer to be 0.2mm ?
Best Answer by JoanTabb:
with a 0.4mm nozzle and layer height 0.1mm, you could set the value to 2, or 3
and that is all you need to change
Opublikowany : 25/10/2023 12:18 pm
RE: Set external walls to be 0.1mm and infilt to 0.2mm ?
Print Settings, Infill, Reducing Printing time...
Opublikowany : 25/10/2023 1:21 pm
Vido
 Vido
(@vido)
Posted by: @joantabb
So I need to set ti to "2" ? And that's it ?
Opublikowany : 25/10/2023 1:26 pm
Opublikowany : 25/10/2023 1:43 pm
