Set external walls to be 0.1mm and infilt to 0.2mm ?
I looked up on internet and I searched in Prüša Slicer but I could not find this option
so basically I want outer layer of object to be 0.1mm so to do 2 passes and infill layer to be 0.2mm ?
Best Answer by JoanTabb:
with a 0.4mm nozzle and layer height 0.1mm, you could set the value to 2, or 3
and that is all you need to change
RE: Set external walls to be 0.1mm and infilt to 0.2mm ?
Print Settings, Infill, Reducing Printing time...
