Sending gcodes from Prusaslicer to Prusa Connect doesn't work anymore.
[Resuelto] Sending gcodes from Prusaslicer to Prusa Connect doesn't work anymore.
Extrutim
(@extrutim)
Hi, by copying the API key and adding a physical printer to my print profile, I got the possibility to send gcodes from the slicer directly to the printer via Prusa Connect.
Now I have created a new printer profile and have done the same with this profile. So I added the API key to the printer profile.
Unfortunately, this doesn't seem to work. After slicing, the small button at the bottom right with which I can send the gcode does not appear.
Does anyone know what to do?
Respondido : 25/01/2024 3:35 pm
RE: Sending gcodes from Prusaslicer to Prusa Connect doesn't work anymore.
Can you post a screenshot of the config window? With the sensitive data blacked out?
Respondido : 26/01/2024 1:03 am
Extrutim
(@extrutim)
I found out for myself today.
I overlooked to switch from Prusa Link to Prusa Connect in the slicer settings of the physical printer under Host Type....
Respondido : 27/01/2024 9:19 am
