Seam shows up a bit strong
Daniel Krueger
(@daniel-krueger)
Hello,
is there a way to hide the seam a bit more?
Printer is original Prusa MK3S+, Seem Position is Aligned, Perimeter Generator is Classic.
This topic was modified 3 years temu 2 times by Daniel Krueger
Opublikowany : 26/12/2022 10:44 am
Snuffleupagus
(@snuffleupagus)
RE: Seam shows up a bit strong
It's hard to tell from the images, however it looks as if the seams are in one of the thinner areas of the print.
If you have an area that's consistently thicker from top to bottom, try moving them to that area.
Perhaps somewhere like this representation.
In case your very new to Slicer I'll mention you can do this with the brush tool in the "Seam painting" Gizmo.
If your able to post a zipped project file, I'd be happy to take a look.
Opublikowany : 26/12/2022 3:49 pm
Daniel Krueger
(@daniel-krueger)
Thx Snuffleupagus,
gonna try tomorrow to move the seam.
I attached the part, which is in 3mf format, as ZIP.
Spacer.3mf
Opublikowany : 26/12/2022 5:48 pm
