Saving Height Range Modifiers
mjseabright
(@mjseabright)
Is there any way to save height range modifiers?
I have set up a height range modifier that I wish to apply to many prints. I can't see a way to do so, other than manually setting up the height range modifiers for each part. This is very tedious if you have a lot of parts to do.
Thanks!
Best Answer by Snuffleupagus:
@mjseabright
Read all the way through.
https://forum.prusa3d.com/forum/prusaslicer/copying-modifier-setttings/
Publié : 16/01/2023 9:25 pm
Snuffleupagus
(@snuffleupagus)
Membre
RE: Saving Height Range Modifiers
@mjseabright
Publié : 16/01/2023 11:35 pm
1 personnes ont aimé
mjseabright
(@mjseabright)
Thanks Snuffleupagus. I've just tested that technique and it works perfectly. It's a cool workaround that will make my life a bit easier.
Would be nice if there was a more obvious and intuitive way to achieve the same thing (like being able to have height range modifiers as part of profiles). But hopefully that will come one day.
Publié : 17/01/2023 1:47 am
Snuffleupagus
(@snuffleupagus)
Membre
@mjseabright
Your welcome,
I had a talk with the guy that made that post, awhile back, and we both agreed we would be happy just to have the ability to save PrusaSlicer generated .3mf project files in the Gallery. That way you could construct your own tools, and just add them rapidly to your projects as needed. Properties and all. But its easy enough to import them I guess, of course it was easy to import models too, and they did it for that. There are some other special things that can be done, I'm sure they will come to light soon enough.
I glad this helped you, share it with others.
Publié : 19/01/2023 5:25 am
