RE: Prusaslider removing parts of my design
This happens because the elements of the model are too thin,
you can address this by:-
making the lines thicker, in Fusion, or
scaling the model to a larger size, or
Using a smaller nozzle on the printer, or
changing the XY compensation value
Arachne and Classic perimeter generators will also provide different results
JoanTabb, Thank you so much. I am new and still have a lot to learn. I made the 0.15 change and it worked perfectly. I am guessing, but does that add 0.15mm to the entire design on the xy planes? Even though that worked I went back to F360 and made everything a little larger. Thank you again!
You are correct it enlarges all XY Dimensions... its a quick and dirty fix, but it works in many instances
prusa slicer will ignore any sections smaller than the Extrusion Width, set in Print Settings >Advanced section of prusa slicer
