Prusaslicer with Ender-3 V2 Extruder stops feeding
Asuswest
(@asuswest)
On layer 3 my extruder stops feeding it will retracted but not go foreword after layer 3
If i use a different slicer it works all the way to a finished part.
It is not a hardware problem
I tried the new version of Prusaslicer and V2.3.2
I have Jyers build v1.3.4 and running OctoPrint V1.6.1
Opublikowany : 29/07/2021 12:37 am
Verify extruder move type
Make sure your startup gcode sends M82/M83 commands for absolute or relative extruder movement that matches your PrusaSlicer settings.
Opublikowany : 29/07/2021 1:07 pm
problem
Did this solve the problem?
Opublikowany : 31/07/2021 1:41 am
Asuswest
(@asuswest)
RE: fixed
thank you for your help got it fixed
Opublikowany : 31/07/2021 5:00 pm
Molly_H20
(@molly_h20)
RE: Prusaslicer with Ender-3 V2 Extruder stops feeding
I am having this same issue.  I just upgraded the board in my Ender 3 Pro to the 4.2.7 32 bit silent board and now it seems to just stop printing mid print.  It doesn't happen when I use Simplify3D.  I am running Octoprint 1 .7.2.  I have a 2nd Ender 3 Pro with the same board and Octoprint version and it has no issues.  I just tried updating the Marlin firmware (from the original to the same that I'm using on the 2nd printer) and that didn't help.  The Marlin firmware is 2.0.
I made sure that both printers have the same startup Gcode which does include M83.  I believe it is the default Gcode for Prusa Slicr.
Opublikowany : 08/03/2022 2:05 pm
