PrusaSlicer settings for AllPHA?
mikkol
(@mikkol)
Dears,
Does anyone have pretested settings for PrusaSlicer to use in an MK4 IS with a 0.6mm nozzle? The colorFabb printing specifications are somewhat difficult for me to convert into PrusaSlicer settings, especially since they predate the IS firmware, which affected temperatures and speeds immensely.
Opublikowany : 05/01/2024 2:31 pm
Tobbe
(@tobbe)
RE: PrusaSlicer settings for AllPHA?
i used the ColorFab pla-pha profile as a base and just changed the bed temp to 0
this means nozzle temp first layer 215 and other layers 210
and that's all.
i have a mk3.9 with mmu3 and i used the satin sheet and printed with a brim.
the benchy i printed looked fine, haven't tried much else
Opublikowany : 25/05/2024 7:32 pm
Charlie Biggs
(@charlie-biggs)
These are the settings for ColorFabb allPHA that I'm using for now on my Mk4 (0.4mm nozzle, smooth PEI sheet, no glue/additives):
Temperature:
First layer: 195 Nozzle, 0 Bed
Other Layers: 190 Nozzle, 0 Bed
Idle Temp: 70
Cooling:
Enable "Keep fan always on"
Disable "Enable Auto Cooling"
Under "Fan settings" in the same page (Expert mode):
Set fan speed to 100% wherever possible,
Disable fan for the first 0 layers
Full fan speed at layer 1
Custom G-Code:
This part is a little out there, but I saw a video (linked here) about using this filament where they recommended bringing the bed temperature up once the print finishes to allow you to remove the prints easier.
I have the following End G-code:
  • ; Filament-specific end gcode
  • G91 ; Change to relative positioning
  • G1 Z70 F300 ; Raise the extruder 70mm away from the print
  • G90 ;  Return to absolute positioning
  • G1 X0 Y200 F300 ; Move extruder to the back-left corner for removing the part
  • M140 S90 ; Set bed temperature to 90C - helps unstick the first layer from the bed
  • M190 S90 ; Wait for bed to reach 90C
  • M140 S60 ; Allow bed to cool to 60C
I'm not a G-Code expert, so definitely review that this is good before running it yourself (it's worked fine for me so far, though).
Print Settings:
Make the brim 8 loops wide and pretty much always have it enabled.
Environment:
If you have an enclosure, open it (or keep it cool some other way). The material really wants everything cold.
I know you posted this a while ago, but hopefully this either helps or you have your own preset now that you might be able to share!
Opublikowany : 13/11/2024 7:42 pm
