PrusaSlicer CLI set extruder
Hey All,
Trying to load a multiple stl files and would like to set the default extruder, is that possible with the CLI?
In the directory containing the stl files I am currently running:
/Applications/Original\ Prusa\ Drivers/PrusaSlicer.app/Contents/MacOS/PrusaSlicer *.stl --single-instance
The stl files are loaded with the 'multi color' default, and I am interested in setting a value for each or even for all.
Postato : 11/05/2022 1:20 am
Postato : 11/05/2022 8:55 am
RE: PrusaSlicer CLI set extruder
Probably the command line interface. This question is probably better asked over on github. While someone here 'may' know, the dev's over there 'should' know 🙂
Postato : 11/05/2022 9:24 am
Topic starter
answered:
@cwbullet yep, CLI is another TLA (three letter acronym), command line interface 😀
@neophyl thanks, I will ping them over at GitHub, but wanted to check to make sure there wasn't something I was missing (and there are a lot of open issues on GitHub).
Postato : 11/05/2022 12:32 pm
