PrusaSlicer 2.9.0 Supports Question
jrichels20
(@jrichels20)
Utenti
Hello.  I am new to PrusaSlicer.  Normally, I would use Fusion 360 directly with my MK3S.  But I upgraded it to the MK4S and Fusion 360 doesn't have a postprocessor yet.  So, to make a simple hollow box, I need supports.   I turned on "Support on build plate only" and expect vertical supports to be generated.  However, I can see that no supports are there.   Am I missing a setting?  Thank you.
Best Answer by 3Delight:
You appear to have "Supports on Build Plate only" selected on the right hand side, try selecting Supports everywhere and see if it helps.
Postato : 09/02/2025 8:28 pm
3Delight
(@3delight)
Moderatore Moderator
RE: PrusaSlicer 2.9.0 Supports Question
You'll need to supply screenshots and/or the original 3fm file (zipped) for people to be able to help you.
Postato : 09/02/2025 10:17 pm
jrichels20
(@jrichels20)
Utenti
I'm not showing the top of the "box".  Clearly, there are no supports.
Postato : 09/02/2025 10:51 pm
3Delight
(@3delight)
Postato : 09/02/2025 10:53 pm
jrichels20
(@jrichels20)
Utenti
Hello.  That did the trick.  The box filled up with support.   Thank you.  (honestly, I thought I had already tried that).
Postato : 09/02/2025 10:57 pm
1 persone hanno apprezzato
