PrusaSlicer 2.9.0 Supports Question
Hello. I am new to PrusaSlicer. Normally, I would use Fusion 360 directly with my MK3S. But I upgraded it to the MK4S and Fusion 360 doesn't have a postprocessor yet. So, to make a simple hollow box, I need supports. I turned on "Support on build plate only" and expect vertical supports to be generated. However, I can see that no supports are there. Am I missing a setting? Thank you.
Best Answer by 3Delight:
You appear to have "Supports on Build Plate only" selected on the right hand side, try selecting Supports everywhere and see if it helps.
RE: PrusaSlicer 2.9.0 Supports Question
You'll need to supply screenshots and/or the original 3fm file (zipped) for people to be able to help you.
Hello. That did the trick. The box filled up with support. Thank you. (honestly, I thought I had already tried that).
