PrusaSlicer 2.8 using insane amount of memory when slicing
3D Gene Designs
(@3d-gene-designs)
So, this is an interesting one for me...I'm trying to slice a batch of 40 of a 3 colored model to print on the XL. The problem is when I go to slice, my CPU spikes for a few seconds and RAM usage maxes out pretty much until the program crashes. I saved the file as a 3mf and tried slicing the same thing through Bambu Studio and had normal amount of CPU/RAM usage I would expect when slicing that file. Is there something I can try to get this sliced for XL? A previous version recommendation perhaps?
Specs/info
  • Prusa Slicer 2.8.0 W64
  • Windows 10 - 64bit (double checked they were the same)
  • AMD Ryzen 9 7900X
  • 32 GB RAM
Going to try 2.7 in the mean time and see if that has same issue.
Postato : 26/08/2024 1:31 am
Babriatis
(@babriatis)
Utenti
RE: PrusaSlicer 2.8 using insane amount of memory when slicing
Were you able to find a solution? I’m having the exact same issue with a Ryzen 9 5900x and 32GB of RAM.
Postato : 08/04/2025 10:29 pm
