PrusaSlicer 2.7 adding unwanted infill/top layers to stl files when sliced
[Solved] PrusaSlicer 2.7 adding unwanted infill/top layers to stl files when sliced
Handyman
(@handyman)
Hello,
Having problems trying to figure out why prusaslicer is adding unwanted infill and top layers to my stl files when slicing.  In the attached example i have a tray that was modeled in fusion 360 and have previously printed fine in prusaslicer 2.6 and earlier.  After updating to prusaslicer 2.7 my tray after being sliced shows top layers and unwanted infill.   I did try reverting to prusaslicer 2.6 and i got the same results.  Any help would be appreciated.  Here is the .3mf zip file UnwantedInfill
Napsal : 03/12/2023 3:59 pm
Handyman
(@handyman)
RE: PrusaSlicer 2.7 adding unwanted infill/top layers to stl files when sliced
Found the Problem.  In Print Settings - Advanced - Slicing Mode was set to "Close Holes".  I changed it back to "Regular" and it solved the problem.  I'm not sure how that got changed but in case anyone runs into this issue this fixed it for me.
Napsal : 03/12/2023 5:55 pm
