PrusaSlicer 2.5 Mac error on start
BigDee
(@bigdee)
just want to report that V2.50 won't start on my M1 MacBook Air:
Although reporting an error as well starting via Terminal works flawlessly:
Regards,
Dieter
Postato : 10/09/2022 9:30 am
RE: PrusaSlicer 2.5 Mac error on start
Not much help but it works flawlessly on my M1 MacBook Air. Maybe something went wrong in the download/install. Also, devs don't hang out here much, if you want to file a bug report head over to Prusaslicer's GitHub site.
Postato : 10/09/2022 10:33 am
Pedroid
(@pedroid)
This looks like a 3D mouse driver is missing. I just checked on my MacMini with a 3DConnexion space mouse.
$ olaf in ~> ls -l /Library/Frameworks/3DconnexionClient.framework/3DconnexionClient
lrwxr-xr-x  1 root  wheel  34 16 Jan  2022 /Library/Frameworks/3DconnexionClient.framework/3DconnexionClient -> Versions/Current/3DconnexionClient
$ olaf in ~> ls -l /Library/Frameworks/3DconnexionClient.framework/Versions/Current/3DconnexionClient
-rw-rw-r--  1 root  wheel  303456 17 Dez  2021 /Library/Frameworks/3DconnexionClient.framework/Versions/Current/3DconnexionClient
$ olaf in ~>
Did you have a 3d mouse and removed it? My Prusaslicer starts with the mouse plugged in and not plugged in.
Postato : 11/09/2022 9:29 am
BigDee
(@bigdee)
Hi Pedroid,
yes i saw that as well. I never owned any of the connexion hardware and i made a clean install when i  bought this (used) MacBook Air. As said it runs without any problem when starting from the terminal.
Regards,
Dieter
Postato : 12/09/2022 5:23 am
Pedroid
(@pedroid)
Ah, sorry Dieter. I should have read your post more carefully. I didn't get it that the programm starts from the terminal though the error happens.
I'm out and would follow @fuchsr's advice to jump to github. "-47" should give someone with code knowledge a hint.
Postato : 14/09/2022 6:44 am
