PrusaSL1Viewer - Open, view, extract and convert SL1 files generated from PrusaSlicer.
A tool that i just made for fun, for the lack of redudancy i'm not replicating info here, head to link for all the description: https://github.com/sn4k3/PrusaSL1Viewer
This tool have 2 days, fell free to test and/or request features, my last goal is convert sl1 files into full pritanble other formats.
RE: PrusaSL1Viewer - Open, view, extract and convert SL1 files generated from PrusaSlicer.
New version released, it now support convert to cbddlp! Again i have no printer to test this, i'm blind working on this -> Test this feature carefully! Looking for testers...
https://github.com/sn4k3/PrusaSL1Viewer/releases/tag/v0.2
- Add cbddlp file format
- Add "convert to" function, allow convert sl1 file to another
- Add EPAX X1 printer
- Change code with abstraction of file formats
New version is up: v0.2.1: https://github.com/sn4k3/PrusaSL1Viewer/releases/tag/v0.2.1
- (Add) Allow open other file formats as well on viewer
- (Add) All thumbnails can now be seen and saved
- (Add) Rotate layer image
- (Add) Close file
- (Change) more abstraction
- (Change) from PNG to BMP compression to speed up bitmap coversion
- (Change) Faster layer preview
New version is up: v0.2.2: https://github.com/sn4k3/PrusaSL1Viewer/releases/tag/v0.2.2
It now also favor single slicer user, with file editing capabilities without reslice
- (Add) File -> Reload
- (Add) File -> Save
- (Add) File -> Save As
- (Add) Can now ajust some print properties
- (Add) 'Initial Layer Count' to status bar
- (Add) Allow cbbdlp format to extract 'File -> Extract'
- (Add) Thumbnail resolution label
- (Add) Layer resolution label
- (Add) Allow save current layer image
- (Change) Rearrange menu edit items to file
- (Change) Edit some shortcuts
- (Change) Strict use dot (.) for real numbers instead of comma (,)
New version is up: v0.3: https://github.com/sn4k3/PrusaSL1Viewer/releases/tag/v0.3
- Add) zcodex file format
- (Add) Zortrax Inkspire Printer
- (Add) Properties menu -- Shows total keys and allow save information to a file
- (Add) "GCode" viewer Tab -- Only for formats that incldue gcode into file (ie: zcodex)
- (Add) Save gcode to a text file
- (Add) Allow to vertical arrange height between thumbnails and properties
- (Improvement) Thumbnail section is now hidden if no thumbnails avaliable
- (Improvement) Thumbnail section now vertical auto scales to the image height on file load
- (Improvement) On "modify properties" window, ENTER key can now be used to accept and submit the form
- (Fixed) Current model height doesn't calculate when viewing cbddlp files
- (Change) Round values up to two decimals
- (Change) Move actual model height near total height, now it shows (actual/total mm)
- (Change) Increase font size
- (Change) Rearrange code
New version 0.3.1: https://github.com/sn4k3/PrusaSL1Viewer/releases/tag/v0.3.1
- (Add) Thumbnails to converted photon and cbddlp files
- (Add) ctb file format
- (Add) Show possible extensions/files under "Convert To" menu
- (Add) Open new file in a new window without lose current work
- (Improvement) Rename and complete some Chitubox properties
- (Improvement) More completion of cbddlp file
- (Improvement) Optimized layer read from cbddlp file
- (Improvement) Add layer hash code to encoded Chitubox layers in order to optimize file size in case of repeated layer images
- (Improvement) GUI thumbnail preview now auto scale splitter height to a max of 400px when change thumbnail
- (Improvement) After convertion program prompt for open the result file in a new window
- (Change) Move layer rotate from view menu to layer menu
- (Change) Cbbdlp convertion name to Chitubox
- (Change) On covert, thumbnails now are resized to match exactly the target thumbnail size
- (Change) GUI will now show thumbnails from smaller to larger
- (Fixed) RetractFeedrate was incorrectly used instead of LiftFeedrate on Zcodex gcode
New version 0.3.2: https://github.com/sn4k3/PrusaSL1Viewer/releases/tag/v0.3.2
- (Add) Show layer differences where daker pixels were also present on previous layer and the white pixels the difference between previous and current layer.
- (Add) Layer preview process time in milliseconds
- (Add) Long operations no longer freeze the GUI and a progress message will shown on those cases
- (Improvement) Cache layers were possible for faster operation
- (Improvement) As layer data is now cached, input file is closed after read, this way file wouldn't be locked for other programs
- (Improvement) Speed up extraction with parallelism
- (Improvement) Extract output folder dialog now open by default on from same folder as input file
- (Improvement) Extract now create a folder with same file name to dump the content
- (Fix) Extract to folder was wiping the target folder, this is now disabled to prevent acidental data lost, target files will be overwritten
- (Add) PHZ file format
- (Add) "Phrozen Sonic Mini" printer
- (Add) Convert Chitubox files to PHZ files and otherwise
- (Add) Convert Chitubox and PHZ files to ZCodex
- (Add) Elapsed seconds to convertion and extract dialog
- (Improvement) "Convert To" menu now only show available formats to convert to, if none menu is disabled
- (Fixed) Enforce cbt encryption
- (Fixed) Not implemented convertions stay processing forever
New Version 0.4: https://github.com/sn4k3/PrusaSL1Viewer/releases
- (Add) CWS file format
- (Add) Nova3D Elfin printer
- (Add) Zoom and pan functions to layer image
- (Add) Pixel editor to add or remove pixels
- (Add) Outline layer showing only borders
- (Add) Image mutators, Erode, Dilate, PyrDownUp, Smooth
- (Add) Task to save operation
- (Add) Printers can be installed from GUI Menu -> About -> Install printers into PrusaSlicer
- (Improvement) Layer Management
- (Improvement) Faster Save and Save As operation
- (Fix) Bad layer image when converting SL1 to PHZ
- (Fix) Corrected EncryptionMode for PHZ files
- (Fix) Save As can change file extension
- (Fix) Save As no longer reload file
- (Fix) SL1 files not accepting float numbers for exposures
- (Fix) SL1 files was calculating the wrong layer count when using slow layer settings
- (Fix) Modifiers can't accept float values
- (Fix) Sonic Mini prints mirroed
- (Fix) Layer resolution shows wrong values
- (Add) Opening, Closing and Gradient Mutators
- (Add) Choose layer range when appling a mutator #1
- (Add) Choose iterations range/fading when appling a mutator (Thanks to Renos Makrosellis)
- (Add) Global and unhandled exceptions are now logged to be easier to report a bug
- (Change) Current layer and layer count text was reduced by 1 to match indexes on mutators
- (Improvement) Better mutator dialogs and explanation
- (Improvement) Compressed GUI images size
- (Fix) SlicerHeader was with wrong data size and affecting .photon, .cbddlp and .cbt (Thanks to Renos Makrosellis)
New version v0.4.2: https://github.com/sn4k3/PrusaSL1Viewer/releases/
- (Add) Zoom times information
- (Add) Island checker, navigation and removal
- (Add) Layer repair with island repair
- (Add) Show mouse coordinates over layer image
- (Fix) Pixel edit cant remove faded AA pixels
- (Fix) Pixel edit cant add white pixels over faded AA pixels
- (Change) Nova3D Elfin printer build volume from 130x70 to 132x74
New version 0.4.2.1: https://github.com/sn4k3/PrusaSL1Viewer/releases
- (Add) PrusaSlicer Printer "AnyCubic Photon"
- (Add) PrusaSlicer Printer "Elegoo Mars Saturn"
- (Add) PrusaSlicer Printer "Elegoo Mars"
- (Add) PrusaSlicer Printer "EPAX X10"
- (Add) PrusaSlicer Printer "EPAX X133 4K Mono"
- (Add) PrusaSlicer Printer "EPAX X156 4K Color"
- (Add) PrusaSlicer Printer "Peopoly Phenom L"
- (Add) PrusaSlicer Printer "Peopoly Phenom Noir"
- (Add) PrusaSlicer Printer "Peopoly Phenom"
- (Add) PrusaSlicer Printer "Phrozen Shuffle 4K"
- (Add) PrusaSlicer Printer "Phrozen Shuffle Lite"
- (Add) PrusaSlicer Printer "Phrozen Shuffle XL"
- (Add) PrusaSlicer Printer "Phrozen Shuffle"
- (Add) PrusaSlicer Printer "Phrozen Sonic"
- (Add) PrusaSlicer Printer "Phrozen Transform"
- (Add) PrusaSlicer Printer "QIDI Shadow5.5"
- (Add) PrusaSlicer Printer "QIDI Shadow6.0 Pro"
- (Add) "Detect" text to compute layers button
- (Add) "Repair" islands button on Islands tab
- (Add) "Highlight islands" button on layer toolbar
- (Add) Possible error cath on island computation
- (Add) After load new file layer is rotated or not based on it width, landscape will not rotate while portrait will
- (Improvement) Highlighted islands now also show AA pixels as a darker yellow
- (Improvement) Island detection now need a certain number of touching pixels to consider a island or not, ie: it can't lay on only one pixel
- (Fix) Island detection now don't consider dark fadded AA pixels as safe land
- (Fix) Epax X1 printer properties
New version 0.4.2.2: https://github.com/sn4k3/PrusaSL1Viewer/releases
- (Add) Shortcut "ESC" under Islands list view to deselect all items
- (Add) Shortcut "CTRL+A" under Islands list view to select all items
- (Add) Shortcut "*" under Islands list view to invert selection
- (Add) Shortcut "CTRL+F" to go to a layer number
- (Change) Layer image is now a RGB image for better manipulation and draws
- (Change) Layer difference now shows previous and next layers (only pixels not present on current layer) were previous are pink and next are cyan, if a pixel are present in both layers a red pixel will be painted.
- (Fix) Save modified layers on .cbddlp and .cbt corrupts the file to print when Anti-Aliasing is used (> 1)
- (Fix) cbdlp layer encoding
Thanks @tiago-2 for the tool. I haven't used all the features but I found it very handy to review the sl1 file and make sure my model failure wasn't in the slicing.
