Prusa Slicer crashing on MacOS 13.5 when initiating export to .STL or .OBJ ???
BoBaCool
(@bobacool)
Here is the report returned by MacOS.
Process: PrusaSlicer [4477]Path: /Volumes/VOLUME/*/PrusaSlicer.app/Contents/MacOS/PrusaSlicerIdentifier: com.prusa3d.slic3r/Version: PrusaSlicer PrusaSlicer-2.6.0+MacOS-x64-202306191415 (PrusaSlicer-2.6.0+MacOS-x64-202306191415)Code Type: ARM-64 (Native)Parent Process: launchd [1]User ID: 501
Date/Time: 2023-08-03 15:25:27.6167 +0200OS Version: macOS 13.5 (22G74)Report Version: 12Anonymous UUID: 42E68BE1-835E-A19D-033F-B127A15C87D9
System Integrity Protection: enabled
Crashed Thread: 0 slic3r_main Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)Exception Codes: KERN_PROTECTION_FAILURE at 0x00000019300fffe8Exception Codes: 0x0000000000000002, 0x00000019300fffe8
Termination Reason: Namespace SIGNAL, Code 10 Bus error: 10Terminating Process: exc handler [4477]
Napsal : 03/08/2023 1:43 pm
RE: Prusa Slicer crashing on MacOS 13.5 when initiating export to .STL or .OBJ ???
Are you trying to report a issue ?  If so the forum isn’t the place to do so. This is a user to user help forum. Bug reports should be made over at the PRUSA slicer GitHub project. It is located here https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc
Napsal : 03/08/2023 4:31 pm
