Proposal: improve bridges and simplify the tuning by changing bridging order
Pfsen
(@pfsen)
I am in the process of tuning my printer for better bridging.
During the process, and in several videos online showing the same, I can see the same behaviour when the bridging settings are not yet optimal, but almost there: the overhang perimeters (the first and last group of bridge lines) become already perfect, but the bridge infill (the inner ones) still sag or disconnect altogether. At the end, when the settings get better, both the outer and inner stay flat.
Let me show Prusa Slicer and a print:
This happens because the overhang perimeters have time to cool down (they are laid down one side and then the other, alternatively), while the bridge infill is done sequentially one after another.
As result, the bridge infill after being extruded gets heated again by the nozzle while extruding the next string. Let's not forget that the metal surface of the nozzle is usually at least 3x as big as the orifice, meaning that the previous bridge infill string gets "ironed" again by the metal surface of the nozzle.
Instead of laying down the bridge infill one after another, changing the order to skip one or two strings and then do those on a second (and if needed a third) pass(es) would allow the bridge infill strings to cool down naturally much more, resulting in the following:
- much simpler tuning of bridge settings
- less need for forced cooling with a fan, meaning that materials which are sensitive to drafts (ABS, nylon, PC, ...) will print better because the intensity of the air moves less.
Obviously there is a price to be paid, which is a non-continuous extrusion, since in the second (and eventually third) passes the head will cross its previous path, and in that (extremely short) period of time, no filament has to be extruded. I think that this is a very minor price to be paid, but it may be relevant for Bowden setups. I suggest the "alternate bridge infill pattern" to be user-selectable and not a default one.
I can post a ticket on Github, but I think that the developers are reading the forum as well. Please let me know.
Postato : 11/05/2020 8:07 pm
RE: Proposal: improve bridges and simplify the tuning by changing bridging order
The best option is GitHub
Postato : 11/05/2020 8:25 pm
2 persone hanno apprezzato
Pfsen
(@pfsen)
I'll do it.
Postato : 11/05/2020 8:35 pm
1 persone hanno apprezzato
Kano Escobar
(@kano-escobar)
Posted by: @lists
I'll do it.
i tried the whole day optimizing this, but to zero success - all of them turn out like this with various speed and flow and fan settings inbetween.
i also suspect the slicer
for me it fills in a bit of the infill after it did the outer 2 perimeters
and after the infill, on one side, starts with the actual bridging infill - outer 2  bridging perimeter layers are connected very nicely and the inners mostly are seperated.
Postato : 24/06/2020 8:09 pm
Take a look at https://forum.prusa3d.com/forum/prusaslicer/poor-surface-due-to-bridging-infill-over-support/ if you havet already where I've been experimenting with some of the extra settings in SuperSlicer, especially the bridging/overhangs.
Postato : 24/06/2020 10:05 pm
Pfsen
(@pfsen)
@neophyl
My printer is being rebuilt so it will be weeks beforei can do testing.
At that point I'll try to modify an existing gcode to implement my idea to see if it works
Postato : 26/06/2020 6:37 am
