PrettyPLA and PrettyPETG filament profiles cause problems with PrusaSlicer
Pedja
(@pedja)
If I use PrettyPLA ( https://prusaslicerprofiles.com/download/pretty-pla-v4-0/) or PrettyPETG ( https://prusaslicerprofiles.com/download/pretty-petg-v3/) i notice very strange behavior of PrusaSlicer 2.2.0.
- I can run slicing only once. I have to change to other profile and then back to be able to rerun slicing.
- After slicing, there is no info about weight of filament used (and some other info like calculated cost). Filament length is calculated.
- I cannot set supports, brim or infill. I can edit options but it has no effect. I cannot even rerun slicing after changing these options.
- I cannot see and edit custom gcode for the profile. If I open profile in plain editor, gcode is there.
I cannot tell if it is faulty profile issue or PrusaSlices has problem handling it. Nevertheless, PrusaSlices should warn that there is some problem, not just silently go nuts.
Veröffentlicht : 04/07/2020 12:55 pm
RE: PrettyPLA and PrettyPETG filament profiles cause problems with PrusaSlicer
Do those 3rd party profiles include filament density and cost values? That would explain some of the missing information.
Veröffentlicht : 04/07/2020 1:50 pm
Pedja
(@pedja)
I found how to set density and cost and that works now. but, that is minor issue.
I also realized when I export gcode it does not follow the same naming scheme as default profiles.
However, main issue is I cannot set supports, brim or infill at all.
Veröffentlicht : 04/07/2020 10:49 pm
I just pulled the Pretty PLA v4.0.ini file into PrusaSlicer 2.2.0+ and am not having any issues.
  • Once I entered filament density and cost, those values show up after slicing.
  • I can change settings and slice at will.
  • I can change print settings, including support and brim at will.
Are you having other issues with your PrusaSlicer install?
Veröffentlicht : 05/07/2020 8:45 pm
Pedja
(@pedja)
@bobstro
Nope. This happens only with PrettyPLA and PrettyPETG profiles. I have few other profiles but all are variations on default profiles I modified myself. They wok ok.
I did not try other custom profiles from prusaslicerprofiles.com. Will try.
Veröffentlicht : 06/07/2020 8:02 am
