RE: Post Process Error Code 1
Here is the python script.
#! python3
import sys
import re
flag = False
out = open('sys.argv[1]'+'_adjusted'+'.gcode', 'w')
with open('sys.argv[1].gcode') as f:
for r in f:
if re.search('G1 F', r):
feedrate = r[3:]
flag = True
print(r[:-1] + ' ' + feedrate) # get rid of new line
elif flag:
r = r[:-1] + ' ' + feedrate
out.write(r)
flag = False # Reset flag
else:
out.write(r)
You are trying to open a file named "sys.argv[1]_adjusted.gcode". You probably meant sys.argv[1]+'_adjusted.gcode'
Similar to above. You probably meant open(sys.argv[1])
And another issue. Your modification need to be put back in the sys.argv[1] file.
I would try making changes like
import os ... infile = sys.argv[1] outfile = infile + '.tmp' out = open(outfile, 'w') with open(infile) as f: .... os.rename(outfile, infile)
Thanks for the feedback. Feel stupid about missing the quotes. I did try it and still get the same error. Maybe I am missing something stupid again. It did process it successfully once i removed the quotes, but when I added your suggestion for using the os i got the same Error Code 1 again.
#! python3
import sys
import re
import os
flag = False
for r in f:
feedrate = r[3:]
flag = True
elif flag:
out.write(r)
else:
out.write(r)
try something like this:
1. remove custom processing scripts.
2. generate gcode as normal, save it
3. run terminal and execute python + script and pass saved gcode file path as parameter - check what is the output of the script, because it looks like it does not work as standalone?
I have done that and it works great. That is what I have been doing to get by for now. Just would be nice to have it integrated into the slicer so it's one less step I have to do.
Hello 😀
Did you ever find a solution?
The issue seems to be the binary gcode,
I turned it off and the script succedded
please check https://github.com/prusa3d/PrusaSlicer/issues/13736
