Post Process Error Code 1
GohDesign
(@gohdesign)
I am having issues PrusaSlicer calling out a script I wrote. I get this error. From looking around I think it is a permission thing.
I am using Windows 11. Python 3.11
Respondido : 30/11/2023 6:07 pm
GohDesign
(@gohdesign)
RE: Post Process Error Code 1
Here is the python script.
#! python3
import sys
import re
flag = False
out = open('sys.argv[1]'+'_adjusted'+'.gcode', 'w')
with open('sys.argv[1].gcode') as f:
    for r in f:
        if re.search('G1 F', r):
            feedrate = r[3:]
            flag = True
            print(r[:-1] + ' ' + feedrate) # get rid of new line
        elif flag:
            r = r[:-1] + ' ' + feedrate
            out.write(r)
            flag = False # Reset flag
        else:
            out.write(r)
Respondido : 30/11/2023 6:29 pm
JimB
 JimB
(@jimb)
You are trying to open a file named "sys.argv[1]_adjusted.gcode".  You probably meant sys.argv[1]+'_adjusted.gcode'
Similar to above.  You probably meant open(sys.argv[1])
And another issue.  Your modification need to be put back in the sys.argv[1] file.
I would try making changes like
import os
infile = sys.argv[1]
outfile = infile + '.tmp'
out = open(outfile, 'w')
with open(infile) as f:
os.rename(outfile, infile)
Respondido : 01/12/2023 6:55 pm
1 les gusta
GohDesign
(@gohdesign)
Thanks for the feedback. Feel stupid about missing the quotes. I did try it and still get the same error. Maybe I am missing something stupid again. It did process it successfully once i removed the quotes, but when I added your suggestion for using the os i got the same Error Code 1 again.
#! python3
import sys
import re
import os
flag = False
    for r in f:
            feedrate = r[3:]
            flag = True
        elif flag:
            out.write(r)
        else:
            out.write(r)
Respondido : 01/12/2023 7:14 pm
_KaszpiR_
(@_kaszpir_)
try something like this:
1. remove custom processing scripts.
2. generate gcode as normal, save it
3. run terminal and execute python + script and pass saved gcode file path as parameter - check what is the output of the script, because it looks like it does not work as standalone?
Respondido : 02/12/2023 3:27 pm
GohDesign
(@gohdesign)
I have done that and it works great. That is what I have been doing to get by for now. Just would be nice to have it integrated into the slicer so it's one less step I have to do.
Respondido : 03/12/2023 6:12 pm
TheYellowDuck
(@theyellowduck)
Miembro
Hello 😀
Did you ever find a solution?
Respondido : 11/06/2024 2:02 pm
Jairo Ledesma
(@jairo-ledesma)
Miembro
The issue seems to be the binary gcode,
I turned it off and the script succedded
please check https://github.com/prusa3d/PrusaSlicer/issues/13736
Respondido : 05/04/2025 5:08 am
