Organic supports not printing on the first layer
Zexsudel
(@zexsudel)
I've tried the 2.6 alpha for the organic supports but all the models I've tested the supports don't print on the first layer, but rather start on the second. I get this is helpful for later layers to make sure there is a space between the model and the supports but for the first layer I need it to actually touch the plate so they stick. With them printing a layer up they don't adhere to the bed and just turn into strings the extruder drags around.
I don't see anything in the setting to force the supports to start on layer 1 instead of 2.
Does anybody have a suggestion for getting them to start actually on the bed?
Respondido : 26/03/2023 7:20 pm
RE: Organic supports not printing on the first layer
Is that 2.6.0 Alpha 5?
Could you please save a project that demonstrates this issue, then Zip Compress the  file, and attach the file on here, so that we can look at the issue you are seeing
Barrel with organic supports
Respondido : 26/03/2023 7:36 pm
Zexsudel
(@zexsudel)
Lowest_poly_thinker_easier_to_print
It is with the alpha 5 version. I've attached a project that shows the problem. You can see layer one there is no support but layer 2 there.
Respondido : 26/03/2023 7:51 pm
Hi Zexsudel
try resetting  your  XY separation between an object and it's support, to the default value
Respondido : 26/03/2023 9:30 pm
Zexsudel
(@zexsudel)
That seemed to have fixed it. Now to give the print a whirl. Thanks for the help.
Respondido : 26/03/2023 9:53 pm
My Pleasure.
I never would have guessed that fix, without the .3mf file.
Respondido : 26/03/2023 10:22 pm
James
(@james-26)
Hi Joan,
I came across this post ... unfortunately, it did not fix my issue. I have organic supports that start on Layer 4 and above ... so obviously missing the connection to the print bed.
Changing the XY separation made no difference.
Any thoughts of what else I can try ?
Thanks.
Respondido : 18/01/2024 5:40 pm
Can you please save your project file for this print, then Zip Compress the file and post a copy to help us see what is happening?
Respondido : 18/01/2024 5:59 pm
James
(@james-26)
Hi Joan,
Please find a simple example attached showing the issue.
(my original file is a bit more complex)
Do let me know what you think and how I can tweak my settings to fix this.
Thanks in advance !
floating_organic_support
Esta publicación ha sido modificada el hace 2 years por James
Respondido : 18/01/2024 9:38 pm
do you need 8.5mm retraction? large retractions often cause blocked nozzles on direct extrusion printer like the mk3 series.
i normally use 0.4mm retraction with PLA filament
if  you have adhesion issues, have you tried 70C on the build plate? do you need to expand the first layer of supports, reducing that setting could reduce print time
i see you are using a generic box, to lift the model off the build plate, does it need to be so big?  a smaller block would improve print time.
you appear to be using generic cylinders as support blockers  with Auto generate supports... which causes a lot of supports
have you considered using support enforcers without the Auto Generate Supports option? and making the support enforcers small enough to protect the tubular holes?
or perhaps use paint on supports for the same purpose?
have you considered combining infill every two layers? or perhaps every 3 layers, to save print time?
if you get strings across the  holes in the model, have you considered setting 'do not cross perimeters?
your original model had a print time of 4Hours 42minutes
the model I have revised has a print time of 2 hours 22 minutes with about 40% saving in filament
I hope these suggestions help. regards Joan
Respondido : 19/01/2024 4:04 am
James
(@james-26)
Hi Joan,
Thanks for the suggestions ... will definitely take them on-board. (and Yes, I added a block to lift up my model that has a curved bottom surface ...)
With regards to this model, I just quickly put together an example to illustrate the organic support issue that I am seeing.
i.e. missing organic supports on lower layers ... and suddenly having them appear on higher layers (floating ???)
Please see the picture below.
Any ideas how i can tweak the support settings to fix this ?
Thanks.
Respondido : 19/01/2024 9:49 am
Organic supports are hollow. By design. You appear to be getting the perimeters as normal. Then they fill in as they get taller.
You may be more comfortable with 'Snug' supports
Regards Joan
Respondido : 19/01/2024 11:23 am
If the model was closer to the build plate. The organic supports would be more solid
Regards Joan
Respondido : 19/01/2024 11:26 am
James
(@james-26)
Hi Joan,
First of all ... Many Thanks for the very quick reply.
I understand that the organic supports are hollow. However, in this case, they are hollow AND "without feet".
Looks like a bug in the slicer software ?
As you can see in the picture above, the organic supports are "suddenly appearing" from Layer 10 onwards ...
As there is nothing in the previous layers (e.g clearly missing in Layer 2 to 4) ... how can they stay on the print bed ?
They are just "floating" elements that will turn into a "mini" birds nest very quickly and will definitely not support the model at that location.
I can convert to Snug or even Rectilinear supports ... but do hope i can get Organic supports to work.
Any thoughts ?
Thanks again ... =)
Respondido : 19/01/2024 11:39 am
Those floating organic supports are a known issue.  Was reported ages ago.  For example from Feb last year https://github.com/prusa3d/PrusaSlicer/issues/9601
Respondido : 19/01/2024 12:47 pm
James
(@james-26)
Thanks Neophyl ... looks like i just have to wait for a new slicer SW...
if there are any workarounds ... please do let us know !
Esta publicación ha sido modificada el hace 2 years 2 veces por James
Respondido : 19/01/2024 2:16 pm
