Organic supports issue
I have a problem with the organic supports. Every time I use them (with the default settings, except for the Z-distance of 0.2mm). I always fail to print because one or several supports appear detached from the base, as if the extruder had hit them.
Is there any guide to find a solution to this, or a specific configuration for organic supports?
Thanks a lot.
Napsal : 20/07/2023 4:48 am
