Odd extrusion artifacts when using concentric fill...
RichardLarson
(@richardlarson)
I am getting some strange extrusion path artifacts when I use concentric fill.  See the yellow-highlighted area in the image attached below.  The interesting thing is that when I rotate the model 180 degrees on the plate, the slicer does not generate these artifacts.
Have I found a bug in the slicer?  Or is this a known issue?
concentric fill showing artifacts
Este debate ha sido modificado el hace 4 years 2 veces por RichardLarson
Respondido : 20/02/2022 1:36 am
