Odd extrusion artifacts when using concentric fill...
I am getting some strange extrusion path artifacts when I use concentric fill. See the yellow-highlighted area in the image attached below. The interesting thing is that when I rotate the model 180 degrees on the plate, the slicer does not generate these artifacts.
Have I found a bug in the slicer? Or is this a known issue?
Dieses Thema wurde geändert Vor 4 years 2 mal von RichardLarson
Veröffentlicht : 20/02/2022 1:36 am
