Need help: Thin Walls: Transition to thicker parts
ristein
(@ristein)
Dear forum,
I'm trying to print the attached part, but I need a little strength in the thin wall.
But since the thin part of the wall is not printed in one go with the thicker parts there won't be a strong bond between them.
Wall thickness is 0.45mm line width is 0.44mm and I'm using Arachne.
PrusaSlicer should print the hole outer Perimeter without stopping .
Is there any way I can achieve this?
Thanks in advance
TrickyPart.zip
Ce sujet a été modifié il y a 3 years par ristein
Publié : 09/12/2022 8:59 am
RE: Need help: Thin Walls: Transition to thicker parts
is this anygood?
Regards Joan
Publié : 09/12/2022 5:49 pm
ristein
(@ristein)
thank you very much.
(perimeter generator to classic fixes it)
Publié : 16/12/2022 10:06 am
