Modifying acceleration per extruder/part/filament (Prusa XL)
Ron
 Ron
(@ron-14)
How to modify "Print Settings / Speed / Acceleration control (advanced)" for only one (Prusa XL extruder / part in the print / filament)?
I have a print, where one extruder is printing text and some other graphic elements. To get good quality of this, the extruder needs to start and stop extrusion very slow. This is needed for good adhesion of details on extrusion start/stop/turn.
Linear advance and retraction/deretraction are already tuned as good as possible.
Currently, I'm achieving this by using very low "Filament / Advanced / Max volumetric speed": 0.05mm³/s
I know that I can significantly reduce print time of this part, because only start/end and turns of the extrusion need to be printed slowly and middle of a straight extrusion can be printed faster.
I don't want to modify acceleration globally, because that will slow down print of the other parts of the print, which can be printed with a normal acceleration rate.
Any suggestions? I feel that I may be able to save half hour per print, and I'm doing hundreds of these prints.
Publié : 05/04/2026 6:00 am
