MMU - Filament vs Extruder - Soluble Support Options
I'd like to print an object with a non-flat bottom, using supports, and ideally, a soluble interface material.
I'm trying to sort out the options
In Plater, I have the Filaments set as in this picture:
In Print Settings I have this:
It results in a slice like this:
I have Wipe Tower disabled, because when enabled, it gives me this warning:
What I want is an easy-to-remove support with minimal hassle.
1) Is there a primer on use of the MMU and soluble filament? I've read the "manuals" and a number of posts (including one that noted confusion between Filament settings and Multiple Extruder settings)
2) I have the latest MMU and MK3 (with one hot end). Am I using the Print Settings\Multiple Extruders settings correctly
-Thanks!
Questa discussione è stata modificata 6 years fa da Dave Elvig
Postato : 24/05/2020 9:15 pm
