Is there an API for PrusaSlicer?
YigalB
(@yigalb-2)
Is there an API for PrusaSlicer, so I could call PrusaSlicer from activate it, including changing setup, slice, set color change, etc.?
I would like to control the slicer via C# (VisualStudio)
Napsal : 07/03/2023 7:07 pm
RE: Is there an API for PrusaSlicer?
No.  There's the command line option.  That has a limited subset of switches and can call a 3mf project file with settings in it but I dont think it will do what you want realistically.
I suspect you will have to open a feature request on the PS github.  Good luck.  https://github.com/prusa3d/PrusaSlicer/issues
Napsal : 07/03/2023 7:51 pm
1 lidem se líbí
YigalB
(@yigalb-2)
Posted by: @neophyl
I opened such a request and got a fast NO: "We are not going to implement such an API any time soon. Contributions are welcome."
Napsal : 08/03/2023 5:45 pm
Slicer isn't really intended for remote operation so the API route complicates matters.  If you want to control the slicer remotely then either set it up on a machine with a VNC server or similar and control it graphically or, and this is nearest to an API, or write an invocation script (Python, or I would use perl) with it's own API and have that compute a command string and launch slicer from the shell.
Napsal : 08/03/2023 7:53 pm
YigalB
(@yigalb-2)
The target of the API is not to remote control.
It is to control the slicer with pre-made scripts.
This will allow to run the design (OpenSCAD in my case) and the slicing automatically, with parameters changing - all  offline.
This post was modified před 3 years by YigalB
Napsal : 09/03/2023 8:21 am
JimB
 JimB
(@jimb)
You might be able to do what you want with the prusa-slicer command line options.
prusa-slicer --help
prusa-slicer --help-fff
I was able to give it an stl file, have it load a config file, slice and save the gcode file which seemed to work.
prusa-slicer --load myconfig.ini --slice test.stl
Although I tried to trigger a color change with the --colorprint-heights option, but I could not get it to do anything.  Don't know if it is broken or I am just not using it right.  You might have to post-process the gcode to inset color changes at the desired places.
Napsal : 09/03/2023 1:12 pm
1 lidem se líbí
OK, so it's not an API problem in the usual sense.
You can invoke an OpenSCAD script from shell (eg: bash) or script with parameters passed from the run-time call.  You can pipe the output into PrusaSlicer OR save an intermediate file with a predefined name then the same script can invoke PrusaSlicer with variables also calculated at run-time.
I have done this at proof-of-concept level with the vague intention of making a web interface for a customisable product that would run through to emailing an STL to the user - but I haven't completed the project, thank for the reminder, maybe I should return to it.
Napsal : 09/03/2023 3:47 pm
1 lidem se líbí
Azonic3D
(@azonic3d-2)
My use case would be to extract completed print data to track cost, inventory levels, uptime, etc. into other programs so that I don't have to manually add this data to a spreadsheet.
How to others here track costing information? Is there another export/connector function I'm not aware of that I can use to achieve this?
Napsal : 03/11/2025 2:40 am
_KaszpiR_
(@_kaszpir_)
In that case PrusaSlicer is not enough, because it produces the input for the printer. You want to track the printer usage via PrusaLink.
Napsal : 03/11/2025 8:22 am
ssmith
(@ssmith)
Have you looked at the OpenPrintTag announcement? So far only tagged Prusament and blank tags available, but the intent looks like much of what you're looking for.
Napsal : 03/11/2025 6:25 pm
1 lidem se líbí
Azonic3D
(@azonic3d-2)
I see this setting in Prusa Connect. Seems like where one would start. However, when I open up PrusaLink, I only get realtime telemetry info and what's stored on the USB drive. Am I missing something? Do I need to configure this somewhere else?
Napsal : 03/11/2025 8:24 pm
Azonic3D
(@azonic3d-2)
Also, any reason my Print History isn't complete? Is it limited to the last 3 months or so? Is there a record somewhere of all prints completed(or stopped/errored out) by the machine?
Napsal : 03/11/2025 8:27 pm
ssmith
(@ssmith)
Posted by: @azonic3d-2
Take a look in the Prusa app (not Connect), the print history there seems to be preserved longer on my machines.
Napsal : 03/11/2025 8:30 pm
