Is it possible to edit .bgcode file?
Bryan P
(@bryan-p)
Hi. I spent quite a while creating a print file with a custom modifier mesh. I now want to change the filament temperature on one color, and I realize my editable model is gone! I have the .bgcode print file, but is there any way to change the temperature setting for one of the colors (extruders) since I have an XL 5 head?
How do I save a project so I can open and edit it in the future? Including all the painstaking work making the modifier mesh fit properly? Do I save a configuration, a project, or what. I don't really understand the differences in what these formats include.
Thank you,
Bryan
Posted : 12/10/2024 5:48 pm
Bryan P
(@bryan-p)
RE: Is it possible to edit .bgcode file?
It turns out you can import your 3MF project, modify it as needed and then save "Project" as .3MF
This is supposed to save all your changes and settings, and can be reimported and edited further.
However, I still need an answer on the BGCODE editing thing.... if anyone knows
Posted : 13/10/2024 2:02 am
Bryan P
(@bryan-p)
I was able to open the bgcode in a text editor. It starts with print information, including printing temperatures and other information.
I am wondering if I make a change to the temperatures and resave the file, if it will use the new settings. - If this is where the variables are defined, or merely a listing for convenience...
GCDE ! Producer=PrusaSlicer 2.8.1+win64!(Y¥ ì printer_model=XL5ISfilament_type=PLA;PLA;PLA;PLA;
PLAfilament_abrasive=0,0,0,0,0
nozzle_diameter=0.4,0.4,0.4,0.4,0.4
nozzle_high_flow=0,0,0,0,0
bed_temperature=60,60,60,60,60
brim_width=0
fill_density=10%
layer_height=0.2
temperature=210,205,225,200,225
ironing=0
support_material=1
extruder_colour=#000000;#DB5182;#3EC0FF;#FFFFFF;#808000
max_layer_z=48.60
objects_info={"objects":[{"name":"sample tool holder wall mount v1.6",
"polygon":[[305.088,299.281],[294.178,299.281],[293.979,306.901],[287.774,306.901],[287.574,299.281],[90.978,299.281],[90.779,306.901],[84.574,306.901],[84.374,299.281],[73.465,299.281],[73.465,244.174],[305.088,244.174]]}]}
filament used [mm]=29516.03, 529.93, 0.00, 29475.22, 0.00
filament used [g]=88.03, 1.58, 0.00, 87.91, 0.00
filament cost=3.19, 0.06, 0.00, 1.85, 0.00
filament used [cm3]=70.99, 1.27, 0.00, 70.90, 0.00
total filament used for wipe tower [g]=13.71
estimated printing time (normal mode)=7h 38m 13s
estimated printing time (silent mode)=9h 35m 55s
ý·ø o qoif Éÿ)))€ÿJJJÿÿ666¿ÿ
@ Èÿ€ÿEEEÿ›ˆÀ £ˆÿ!!!€ÿ Æÿ,,,€ÿCCCÿ5ˆþ¿ˆþBBB©ˆ Äÿ;;;ÿ©ˆˆ€ˆˆÀ°ˆ Âÿ'''¿ÿ444ÿÀ¤ˆ‹ˆþ ÃþVVV Á•ˆÀ†ˆ5Äþ''' Àÿ###€ÿEEEÿ›ˆ€ˆþ Åþ#1"1 þ"""5ÅþL6>þOOO•ˆÀ$þ Äþ$Àþ(((©ˆUŽˆ‘ˆ$þ Äþþ@@@µˆÀU0"þ Ä25þ,,,þXXX,Uþ$$$5Ã5 þ]]]ÃU;35Ãþ)))?,¥ˆ@UUˆ5À?,7$¢ˆ$7Šˆˆˆ†ˆþPPP0£ˆ(7$?1%0À?;
and so on......
Posted : 13/10/2024 2:17 am
