Import recent STL, OBJ, AMF, ...
Please could you consider adding a menu entry showing the 9 recently imported object files.
I'm making intensive use of imports and having to always select the same file within the file dialog is really annoying (I'm always using the same file name for export from FreeCAD and import in PS).
Thanks!
Bernard
RE: Import recent STL, OBJ, AMF, ...
Nice idea. Better posted to the Prusaslicer's GitHub site though as it's more likely to be seen there. Double check that there's not an existing request. Which wouldn't surprise me.
HI Bernard. This is mainly a user to user forum. The devs rarely pop in. The correct place to make feature requests (and report issues) is the Prusa Slicer github. Items raised there get an issue number, will be seen by Prusa staff and can be tracked.
https://github.com/prusa3d/PrusaSlicer/issues
Please before opening a new issue do a thorough search of both open and closed issues with as many key words as you can think of. If you don't find a match in the over 2300 open and over 6000 closed ones then follow the issue guide and include all the requested info when doing so.
Cheers
Hi, thank you for your responses. It helped me to confirm such a feature does not exist yet.
After a quick search on open issues I didn't find any similar request. Here is the one I added : https://github.com/prusa3d/PrusaSlicer/issues/9140
To be continued...
Cheers
