How to show/access machine limits on custom printer?
Bomboy300
(@bomboy300)
Hello,  I'm setting up a customer printer profile, and need access to the machine limits settings on the printer settings tab.  The option is there for any of the default Prusa printers, but the machine limits tab goes away once I change to my custom printer profile.  Any way I can get access to the machine limits on my custom printer?
The default Z speed/acceleration it too much for my printer and is causing it to skip a lot of steps.  any help or work arounds would be greatly appreciated.  Thanks!
Napsal : 02/11/2020 10:42 pm
RE: How to show/access machine limits on custom printer?
I had no issues creating a profile for my Artillery Sidewinder X1. You are in expert mode, correct?
Napsal : 03/11/2020 12:05 am
Bomboy300
(@bomboy300)
Yes, I'm in expert mode.  If I use the wizard to create a custom print profile the Machine Limits option is not available.   I will try and just copy a Prusa Printer profile and adapt it to my custom printer and see if that works.  I don't know why the machine limits isn't an option for custom printers.  Seems to me that would be important.   attached are two pictures,  one of the Prusa Printer settings, and one of my custom printer settings.  As you can see, one has Machine Limits, one does not.  Any ideas how to fix this would be awesome.  Thanks
Napsal : 03/11/2020 4:05 pm
It’s because you have Repetier selected as g code flavour I think. The Prusa printer will be using Marlin gcode.
Napsal : 03/11/2020 4:54 pm
1 lidem se líbí
Bomboy300
(@bomboy300)
Ahh,  you are correct,  thank you.  if I switch to Marlin I get access to the Machine limits.  Now I just need to figure out how to upgrade my firmware from Repetier to Marlin....
Napsal : 05/11/2020 5:44 pm
