How reduce elephants foot worked in Prusa slicer
4XS
 4XS
(@4xs)
Which part of the slicer setting is responsible for eliminating elephants foot? Im attempt to reproduce that configuration on my other slicer for a different machine. But first I need to find it.
Best Answer by Tim Weston:
In PrusaSlicer's 'Print Settings' tab, make sure to select the 'Advanced' or 'Expert' mode. There will then be a sub-tab visible called 'Advanced'. In there you will find the 'Elephant foot compensation' value at the bottom of the 'Slicing' section.
Cheers,
Tim
Napsal : 11/12/2022 6:49 am
Tim Weston
(@tim-weston)
RE: How reduce elephants foot worked in Prusa slicer
Cheers,
Tim
Napsal : 11/12/2022 10:28 am
There's also the magnifying glass icon on the top of the window that you can use to search for settings.
Napsal : 11/12/2022 5:27 pm
