How do I create a full copy of a printer setting
FrankT
(@frankt)
When I run the Configuration Wizard for my Mk3S MMU2S, I have an option to include an extra configuration for a .6 nozzle. Since I have a .5 nozzle, this is a nice starting point. After completing the wizard, I can adjust some settings and save these printer settings.
The configuration is now saved a a User Settings. But now all the Print setting system presets have gone. No default set of print heights anymore.
This is weird. Why can't I just create a copy of the complete 'printer' to simply create alternate versions for different nozzles? Am I missing something?
Best Answer by Lichtjaeger:
Select the 0.6 printer profile again. Then go to the "Print Settings" tab. You need at least Advanced mode to see a "Dependencies" page in the navigation.
At the end of the "Compatible printers condition", you will find the size statement that affects the visibility. Set it to 0.5 to make a print profile for your 0.5 printer profile.
You will also need to adjust the "Extrusion width" settings under "Advanced".
Repeat for all needed profiles.
Posted : 05/11/2019 1:34 pm
Lichtjaeger
(@lichtjaeger)
RE: How do I create a full copy of a printer setting
Posted : 05/11/2019 3:00 pm
@lichtjaeger You can also use ">=" or "<=" to allow a profile to be used more flexibly. More notes here.
Posted : 05/11/2019 11:35 pm
Lichtjaeger
(@lichtjaeger)
Posted by: @bobstro
Yes, you can, but I would not recommend it for something like the extrusion width, that is directly connected to one nozzle size.
Posted : 06/11/2019 2:13 am
Posted by: @lichtjaeger
I use it to validate layer heights, ensuring selected height profiles are only shown for suitable nozzle sizes.
Posted : 06/11/2019 3:08 am
