How can you remove the brim ?
GregD
(@gregd)
it looks like I can't completely remove the brim.
When I change it to "no brim" and slice again, it puts again a brim. Is that a bug ?
config :
PrusaSlicerVersion: 2.4.0+linux-x64Build: PrusaSlicer-2.4.0+linux-x64-202112211614
Operating System: UnixSystem Architecture: 64 bitSystem Version: Linux 5.4.0-96-generic x86_64Total RAM size [MB]: 12,548MBOpenGL installationGL version: 4.6.0 NVIDIA 470.86Vendor: NVIDIA CorporationRenderer: Quadro P620/PCIe/SSE2GLSL version: 4.60 NVIDIA
Publié : 27/01/2022 8:06 pm
Files > Save Project as
Publié : 27/01/2022 11:41 pm
GregD
(@gregd)
RE: How can you remove the brim ?
Here...testnobrimatall
There's always a "ring" around. I could not find how to remove it..
thanks Diem !
Publié : 27/01/2022 11:48 pm
sylviatrilling
(@sylviatrilling)
That ring around it is a skirt which is not the same as a brim, but they are on the same page in the slicer. You can set 'Skirt loops' to zero to get rid of it. But personally I prefer printing the skirt. It doesn't affect the print object in any way, but it gives the hot end a little running start for extruding and a last chance to clear wobbles or blobs before the actual print starts.
Mk3S+,SL1S
Publié : 28/01/2022 12:51 am
@sylviatrilling is correct. The skirt is sometimes useful to help the first layer stick if there is a cool draft.
You are using 0.1mm detail print settings, that part would probably be stronger at 0.2mm.
Publié : 28/01/2022 3:41 am
GregD
(@gregd)
All clear! Thanks for your answers !
Publié : 28/01/2022 9:15 am
