help with pusa slicer putting prime line mid print leaving gap in model please
[Solved] help with pusa slicer putting prime line mid print leaving gap in model please
steve litster
(@steve-litster)
Hi all im new to prusa, i made the switch from cura for the 2.6 features if im honest. I have used it a few times in the past but recently when i put 2.5 on or 2.6 alpha 3 or 4 and slice a model, it looks fine until the preview after slicing then i have a layer missing mid model (whether i fix the model in slicer, mesh mixer or other software, or even using a model that doesnt need fixing) and a prime line at the same layer?!
I tried everything i could think of, reinstalling both versions, getting alpha 4, compatibility mode, admin, diff models that i knew to work, eventually i tried on my daughters laptop and the problem isnt there but as i dont have access to it all the time and my pc is faster im looking to fix it if possible.
I will attach a zip with the .3mf of the ghost mask, i havent fixed it in the project as i never had to on my daughters to get a successful print.
Have i made a school boy error? or has this happend to others?
Any help or even pointing in right dirtection would be hugely appreciated.
Cheers
steve
cod
Best Answer by Neophyl:
I know WHATS causing it, I just don't know WHY its causing it.  Its your -20 Z offset in your printer configuration.  Remove that and it slices fine.
This topic was modified před 3 years by steve litster
Napsal : 05/03/2023 11:55 am
steve litster
(@steve-litster)
RE: help with pusa slicer putting prime line mid print leaving gap in model please
Anybody? I really want to be able to use prusa going forward and came here thinking this would be the best place for this sort of problem 😥
Napsal : 07/03/2023 6:26 pm
Napsal : 07/03/2023 6:52 pm
steve litster
(@steve-litster)
Thank you so much for taking the time to help! I really do appreciate it. I had set an offset while setting up the bltouch, if need be I'll go back to manual bed levelling as I have alot of experience with it.
I'll give this a go and report back, hopefully with a successful print.
Again thanks for the response I was getting abit deflated not being able to figure it out myself and I don't have any friends that print, my only source of info is Google, Facebook groups and now here.
Take care
Napsal : 07/03/2023 7:05 pm
1 lidem se líbí
steve litster
(@steve-litster)
Your a god among insects, thank you again. I was going crazy and as a noob to prusa slicer never even noticed that as I imagined it was related to my bltouch offset on the machine itself.
Take care
Napsal : 07/03/2023 7:17 pm
René
(@rene-3)
When I load your file into prusa slicer it says there are errors in your file.
Fix it with prusa slicer's built-in netfabb option.
Click the exclamation mark.
Napsal : 07/03/2023 7:22 pm
fixing the errors does not fix the prime line, unfortunately,
Napsal : 07/03/2023 7:23 pm
1 lidem se líbí
steve litster
(@steve-litster)
Hi Joan is right, fixing the errors doesn't change the prime line, also on my daughter laptop the file printed successfully without fixing the errors. I really appreciate you taking the time to reply but it was as simple as changing the z offset to zero. I feel stupid and humbled at the same time, as it is working fine now and I can continue to learn prusa slicer and benefit from its new features.
Take care
Napsal : 07/03/2023 7:28 pm
