Help: PrusaSlicer 2.2.0+ can't process an STL file
sergen
(@sergen)
PrusaSlicer (see system info below) hangs at any attempt to process the below Thingiverse file.
https://cdn.thingiverse.com/assets/e9/12/64/d3/91/Primer_Flipper_Round_125mm_Bottom.stl
Any help in going around the problem?
PrusaSlicer
Version: 2.2.0+
Build: PrusaSlicer-2.2.0+-202003211132
Operating System: Macintosh
System Architecture: 64 bit
System Version: macOS Catalina Version 10.15.5 (Build 19F101)
Total RAM size [MB]: 17,180MB
OpenGL installation
GL version: 2.1 INTEL-14.6.18
Vendor: Intel Inc.
Renderer: Intel(R) Iris(TM) Plus Graphics 655
GLSL version: 1.20
Installed extensions:
GL_APPLE_aux_depth_stencil
GL_APPLE_client_storage
GL_APPLE_element_array
GL_APPLE_fence
GL_APPLE_float_pixels
GL_APPLE_flush_buffer_range
GL_APPLE_flush_render
GL_APPLE_object_purgeable
GL_APPLE_packed_pixels
GL_APPLE_pixel_buffer
GL_APPLE_rgb_422
GL_APPLE_row_bytes
GL_APPLE_specular_vector
GL_APPLE_texture_range
GL_APPLE_transform_hint
GL_APPLE_vertex_array_object
GL_APPLE_vertex_array_range
GL_APPLE_vertex_point_size
GL_APPLE_vertex_program_evaluators
GL_APPLE_ycbcr_422
GL_ARB_color_buffer_float
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_instanced_arrays
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_provoking_vertex
GL_ARB_seamless_cube_map
GL_ARB_shader_objects
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shadow
GL_ARB_sync
GL_ARB_texture_border_clamp
GL_ARB_texture_compression
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_non_power_of_two
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_transpose_matrix
GL_ARB_vertex_array_bgra
GL_ARB_vertex_blend
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_window_pos
GL_ATI_separate_stencil
GL_ATI_texture_env_combine3
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_debug_label
GL_EXT_debug_marker
GL_EXT_draw_buffers2
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture_array
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_s3tc
GL_EXT_texture_env_add
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod_bias
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_timer_query
GL_EXT_transform_feedback
GL_EXT_vertex_array_bgra
GL_IBM_rasterpos_clip
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_depth_clamp
GL_NV_fog_distance
GL_NV_light_max_exponent
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
Postato : 18/07/2020 9:19 am
RE: Help: PrusaSlicer 2.2.0+ can't process an STL file
Hi Serge,
Did you sort this file?
I couldn't find anything  obvious wrong with it.
I tried fixing with NetFabb. no noticeable change,
Tried fixing with Mesh Mixer, No noticeable change
Left Slicer running in the background, and the file seems to have eventually sliced
I have attached the G code for PLA.
Regards Joan
Attachment removed
Postato : 18/07/2020 9:33 pm
sergen
(@sergen)
Joan,
No, I did not sort it out. In my case, PrusaSlicer does not produce any output on Import and Slice commands. Thank you for the G code! May I bother you to redo it in PETG? I don't have PLA.
Thanks
Serge
Postato : 18/07/2020 11:14 pm
yeah its a fully valid file and it will eventually finish but it takes an age on my machine.  I had to leave it over 30 minutes to complete and it looks like its crashed as it doesnt really respond to the cancel button.
Might be a good one to post over on github for the devs to use as a torture test.
Postato : 18/07/2020 11:27 pm
sergen
(@sergen)
Joan,
After almost an hour I got my G code file generated.
Serge
Postato : 19/07/2020 12:24 am
Excelent!
Joan
Postato : 19/07/2020 1:08 am
jweaver
(@jweaver)
I was intreaged to see how my PC would handle this.. But I now want to know whats a "Primer Flipper"? I went to the Thingiverse page and that doens't realy help.. It just states that its a "Primer Flipper" so I guess you will know what it is if you are the target audience.. But I want to know now..... Any ideas?
Edit. I worked it out.. Its a Bullet reloading thing... I know what "primers" they are talking about now...
Questo post è stato modificato 6 years fa da jweaver
Postato : 19/07/2020 10:34 am
sergen
(@sergen)
@jweaver
See it in use:
Postato : 19/07/2020 1:17 pm
For them thar fire arms...
Mine is integrated with the hand primer tools
Postato : 19/07/2020 4:46 pm
sergen
(@sergen)
@joantabb
Your Chi is obviously stronger than mine. I am cheating with a progressive press, and am a beginner even at that one.
Serge
Postato : 20/07/2020 4:35 am
