[Resuelto] grid support looks different
Heiko910
(@heiko910)
Hi there,
I am working on a larger print and have determined to use Grid as my support pattern.
I have used it many times in the past but suddenly it has changed in appearance and structure. I am using Prusaslicer 2.9.0
Can someone explain why it looks like a vertical zig zag pattern? Did I accidently enable this, how do change back to solid wall grid support? See pictures
thanks
Respondido : 20/01/2025 12:29 am
Heiko910
(@heiko910)
RE: grid support looks different
Respondido : 20/01/2025 1:06 am
Does it look like this in the slicer preview? As usual, it's always best to upload a zip compressed 3mf project file so we can see all your settings.
Respondido : 20/01/2025 4:18 pm
Heiko910
(@heiko910)
In the preview it doesn't look like that. I will upload a 3mf later this afternoon. Thanks
Respondido : 20/01/2025 7:33 pm
Heiko910
(@heiko910)
dust_adapter_v5_-_top(2)
Here is the 3mf file compressed as a zip file. I would appreciate your help. thanks
Respondido : 21/01/2025 1:29 am
Heiko910
(@heiko910)
I experimented a bit more.
I thought mazbe the PETG profile I was using was just bad.
I changed filament to PLA and switch to a PLA profile but the problem with the funky looking support is persistent.
I noticed that in Print Settings under Advance the extrusion width for supports is set to .35mm - narrower than the nozzle diameter. could that be it?
I will test and report back.
Respondido : 21/01/2025 9:12 pm
Heiko910
(@heiko910)
I am not sure if anyone else has experienced this before, maybe I am the only one who cares but it is fixed.
The extrusion width for supports should by default be set to 0. When it is set to 0 the system just uses the default extrusion width.
#fixed
Respondido : 21/01/2025 9:37 pm
