Getting pre-baked Ramming g-code?
Asraff Amzani
(@asraff-amzani)
Hi, I tried to search ways (maybe they're hidden?) to get the generated ramming g-code instead of its raw values present at the end of the gcode files but I couldn't find it.
The reason behind this 'quest' is so that I'm able to use it on the custom g-code section instead of extracting/copy pasting the ramming sequence from exported gcode file. Each filament type/brand has their own ramming settings set by prusa teams such as abs and petg has different ramming settings. (filament tab > advanced > ramming settings).
So, once again, are there any ways to get a pre-baked ramming gcode that sourced from the above instead copy pasting the exported gcode file? Even the prusa help page > placeholder/macro didn't have such thing while the ramming parameter at the exported gcode file is only the following
; filament_ramming_parameters = "120 140 4.70968 4.74194 4.77419 4.80645 4.83871 4.87097 4.90323 5 5.25806 5.67742 6.29032 7.06452 7.83871 8.3871| 0.05 4.72901 0.45 4.73545 0.95 4.83226 1.45 4.88067 1.95 5.05483 2.45 5.93553 2.95 7.53556 3.45 8.6323 3.95 7.6 4.45 7.6 4.95 7.6";"120 140 4.70968 4.74194 4.77419 4.80645 4.83871 4.87097 4.90323 5 5.25806 5.67742 6.29032 7.06452 7.83871 8.3871| 0.05 4.72901 0.45 4.73545 0.95 4.83226 1.45 4.88067 1.95 5.05483 2.45 5.93553 2.95 7.53556 3.45 8.6323 3.95 7.6 4.45 7.6 4.95 7.6";"120 140 4.70968 4.74194 4.77419 4.80645 4.83871 4.87097 4.90323 5 5.25806 5.67742 6.29032 7.06452 7.83871 8.3871| 0.05 4.72901 0.45 4.73545 0.95 4.83226 1.45 4.88067 1.95 5.05483 2.45 5.93553 2.95 7.53556 3.45 8.6323 3.95 7.6 4.45 7.6 4.95 7.6";"120 140 4.70968 4.74194 4.77419 4.80645 4.83871 4.87097 4.90323 5 5.25806 5.67742 6.29032 7.06452 7.83871 8.3871| 0.05 4.72901 0.45 4.73545 0.95 4.83226 1.45 4.88067 1.95 5.05483 2.45 5.93553 2.95 7.53556 3.45 8.6323 3.95 7.6 4.45 7.6 4.95 7.6";"120 140 4.70968 4.74194 4.77419 4.80645 4.83871 4.87097 4.90323 5 5.25806 5.67742 6.29032 7.06452 7.83871 8.3871| 0.05 4.72901 0.45 4.73545 0.95 4.83226 1.45 4.88067 1.95 5.05483 2.45 5.93553 2.95 7.53556 3.45 8.6323 3.95 7.6 4.45 7.6 4.95 7.6"
Sorry for my seemingly bad explanation, I don't really know how to explain
Opublikowany : 04/12/2022 11:10 am
