.gcode to image?
Woogie
(@woogie)
.gcode to image?
Hello,
Is there a way to have PSlicer open a .gcode file and show the results... I was looking for a way to just view a part/image of the printed part from the .gcode. I found a few online viewers but I've gotten mixed results from them.
Regards.
Napsal : 18/07/2020 8:46 pm
RE: .gcode to image?
Posted by: @woogie
Hello,
Regards.
There is currently no way to view the gcode in PS. As you have already found, there are several online viewers. S3d would be another option.
Take a look at this post: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/anyone-know-of-a-gcode-viewer-that-can-show-the-object-dimensions/#post-199256
Napsal : 18/07/2020 9:53 pm
jsw
 jsw
(@jsw)
There is an application out there called Voxelizer which will supposedly convert .gcode files to .stl files and, of course, view them.
I downloaded it a while ago and installed it, but when I launched it, it wanted me to log in (to an off-line application?) or create an account, so I gave up with it.  If I really need it I'll create an account with a throw-away email.
Napsal : 18/07/2020 10:10 pm
Woogie
(@woogie)
I gave the Gcode-Analyzer a try, but it only seems to work online. The downloaded copy to run it locally (from thingiverse) doesn't seem to work.
I did reach out to jweaver (from that post you mentioned) to see if he had any further success.
Thanks for your reply! 🙂
Napsal : 18/07/2020 10:20 pm
Woogie
(@woogie)
@jsw
I connected .gcode to my CAMotics software and it kinda does what I was looking for. It's probably enough for me to distinguish one version/file from another if I know what I'm looking for. A ".gcode to image" kind'a seems like an easy thing (coming from a non-programmer). Maybe one day. I did find an Google/Android program called Graphite - STL/GCode Viewer, but it's only for Android. Yes I could run a Android emulator in windows, but that seems excessive. But it does look to be what I'd like to have.
https://play.google.com/store/apps/details?id=com.rootzero.graphite&hl=en_US
Napsal : 18/07/2020 10:36 pm
Am i correct that you want some software where you can load a sliced gcode file in and that will then show you a visualisation of the finished output ?
If so Prusa used to have some software called Prusa Control which could do that.  The defunct webpage is here https://help.prusa3d.com/en/article/prusacontrol_2217
It looks like you can download it still from their github repository here https://github.com/prusa3d/PrusaControl/releases
Napsal : 18/07/2020 11:11 pm
Woogie
(@woogie)
@neophyl
That is perfect! When I opened it for the first time... it tried to get me to update to the latest prusa slicer! 🙂
Thank you!
Napsal : 18/07/2020 11:18 pm
jsw
 jsw
(@jsw)
Thank you.  I'll download and try it when I get some time later tonight.
Napsal : 18/07/2020 11:52 pm
Woogie
(@woogie)
Well, it's just about what I wanted... it will only let me see one layer at a time. I can turn on individual layers and get a good visual for what I need; it's enough for the moment.
Napsal : 19/07/2020 12:21 am
franpoli
(@franpoli)
Pronterface is an essential tool in my 3D printing arsenal. It's free, open-source. licensed under the GNU GPL3. The application features g-code preview and manipulation.
Napsal : 19/07/2020 2:27 am
Pronterface is also part of the Prusa Drivers download package on my windows PC.
Napsal : 19/07/2020 10:53 am
Woogie
(@woogie)
Pronterface/Print run is fantastic... that is more like what I was expecting. @jsw... just go right to this.
Thanks francois-p3 and joantabb!
Napsal : 19/07/2020 1:20 pm
