for support enforces only - not behaving as expected
Rob Latour
(@rob-latour)
Please see attached two screenshots (both combined inside the one attached screenshot)
not sure why supports go all the way down to the print bed - I had wanted them to only start midway up the print
Is this something I am doing wrong?
I tried to add a blocker under the enforcer, but that did not work.
Any ideas?
Best Answer by towlerg:
@rob-latour
I'm surprised those other features didn't need support.
Select the part and manipulate it till you can see the underside of the SD slot then select Paint-on supports. I think the radiused edges and the shallow feature were part of the reason the slicer was not giving you what you want. I know that chamfers are not as pretty as radius corners but they certainly simplify 3d printing.
Postato : 07/02/2021 7:06 pm
Rob Latour
(@rob-latour)
RE: for support enforces only - not behaving as expected
updated photo to show original as well
Postato : 07/02/2021 7:16 pm
jsw
 jsw
(@jsw)
Slicers will often build the support tower from the build plate and not the surface below what's supported.  This should not be an issue in most cases.  Just be sure that you are using the support parameters for break-away supports and not the defaults for soluble supports.
Postato : 07/02/2021 10:03 pm
Rob Latour
(@rob-latour)
Thanks.  I just added the support enforcements and didn't fiddle with any other settings - was there one that would have made a difference?
Postato : 07/02/2021 11:49 pm
towlerg
(@towlerg)
Try using paint-on enforcers, just a narrow strip (you can set brush size). Post your STL, but note that you need to zip it up.
Postato : 08/02/2021 10:09 am
Rob Latour
(@rob-latour)
Yes, actually I had tried that first.  Same somewhat unexpected results; support goes all the way down to the base.
Postato : 13/02/2021 12:07 am
towlerg
(@towlerg)
Post your STL
Postato : 13/02/2021 11:18 am
Rob Latour
(@rob-latour)
ok thanks - you can get the .stl file as well as the .fd3 file used to create it here:
https://cults3d.com/en/3d-model/tool/raspberry-pi-4-flirc-and-ssd-encloser
Postato : 13/02/2021 1:11 pm
towlerg
(@towlerg)
Sorry I misposted, I meant
Post your .3MF project file.
Postato : 13/02/2021 10:10 pm
Rob Latour
(@rob-latour)
No problem.
Attached in a zip file are the .3mf and .stl files.
In this case, I painted on the support and even tried to put a blocker in.
Same results if I just used a block for the enforcer with or without the blocker.
Attachment removed
Postato : 13/02/2021 10:26 pm
towlerg
(@towlerg)
@rob-latour
Don't know if this is what you were looking for, I've supported the sd slot, the oblong hole and the hanging roof.
Attachment removed
Postato : 14/02/2021 10:24 am
Rob Latour
(@rob-latour)
Only the SD slot needs support, the other two (the oblong hole and the hanging roof) print fine without supports.
Would you mind sharing how you accomplished what you did?  It's not apparent to me.
Thanks
Postato : 14/02/2021 12:35 pm
towlerg
(@towlerg)
@rob-latour
Postato : 14/02/2021 9:08 pm
1 persone hanno apprezzato
Rob Latour
(@rob-latour)
Got it.
Thank you so much.
I guess I was too roughly painting the underside of the top of the SD slot.
Following your suggestion, when I zoomed in quite a bit, and painted it with a circle having a brush size of 0.4 (the smallest possible) it worked like a charm.
Again, with thanks, Rob
Postato : 14/02/2021 10:49 pm
