First Layer Temperature for Second Extruder?
I am trying to figure out if it is possible to use the first_layer_temperature parameter for each extruder independantly.
I have an IDEX machine where I am printing a raft and supports from extruder 1, and I would like the first layer of extruder 2 to be utilized on the first layer of material going down after the raft and base support layer.
Basically on the first tool change I want extruder 2 to be set to it's first_layer_temperature.
I know there is total number of tool changes as a parameter? Is there a "current tool change number" or something similar I could use in the Tool Change G-code area of the Printer Settings?
Thanks.
Opublikowany : 09/02/2024 3:11 pm
