filament blocked always at 39 cm
Basteam
(@basteam)
Hello. For some time, during the printing of my prusa MK3, the temperature drops and my filament becomes blocked.
This always happens at 39cm. It's on all my impressions that's why I think it comes from the slicer. Thank you for your help.
Respondido : 21/07/2022 8:37 pm
Swiss_Cheese
(@swiss_cheese)
It's more likely that you have a short in a wire or a loose connection, and it occurs around 39cm.
I've seen it happen that folks that weren't very good with the slicer software have inadvertently added commands that could also cause such a thing.
Esta publicación ha sido modificada el hace 4 years por Swiss_Cheese
The Filament Whisperer
Respondido : 22/07/2022 12:02 am
RE: filament blocked always at 39 cm
How do you print something 39cm high on a mk3 ? That’s way more than the max z height.
Respondido : 22/07/2022 4:47 am
Basteam
(@basteam)
Excuse me 39mm....
The temperature probe is new, the heating resistance is new. I don't think it's a cable. But I don't see where to look in Prusa Slicer
Respondido : 22/07/2022 6:08 am
Does it happen with anything you're trying to print? It feels more hardware related (wie issue as swiss_cheese) suggested but if it's in prusaslicer the first place I would check is in Printer Settings>Custom Gcode and see if there's anything different than the default.
Respondido : 22/07/2022 10:54 am
Basteam
(@basteam)
RE: filament blocked always at 39mm
Hello. Yes it does that on everything I print over 39 mm. I also changed the motherboard of the prusa that was dead. I checked that all the cables are properly connected. But everything is good. I would look in the Gcode.Thank you
Respondido : 23/07/2022 8:16 am
If it's repeatedly positional in the Z direction that suggests that something is pulled open circuit at that position.
Check the cables in the e-axis wire bundle, one may have work-hardened and cracked the conductor within the insulation so that it opens at that flexure.
Respondido : 23/07/2022 10:08 am
Basteam
(@basteam)
RE: filament blocked always at 39 mm
I will verify that. Thank you for your answers.
Respondido : 25/07/2022 4:12 am
