Feature request: connect the islands using single first layer lines, like streets connecting cities on a map
When printing the popular "flexible" models, there are lots of small islands for each part.
It would be great if the islands were connected with a single line to their 3 closest neighbors - the single line would be easy to remove, it wouldn't be the big fight that a a brim would be, and it would greatly reduce the chance of a small island "letting go" during the first few layers.
For example, imagine if it added the green lines in a smart way: https://photos.app.goo.gl/xviHdz2oEk6aomgP8
That is so little material used, but would really keep one part from "popping off" - or if it did pop off, there would be good odds that the print could continue.
No, no, no, no, no definitely no. That would make all print-in-place mechanisms, bearings and gear chains print seized and in most cases unuseable.
If you are having adhesion problems with only a couple of dozen start points then look to cleaning your print sheet.
Here's an example with a couple of hundred start points, this sort of print should be achievable with any well maintained printer.
RE: Feature request: connect the islands using single first layer lines, like streets connecting cities on a map
No, no, no, no, no I'm not saying do it ALL the time. You are 100% right, that would be a horrible idea.
Just to do it when requested - like when requesting to auto-generate supports, this is a horizontal version of supports!
Due to various and complex shapes that can show u it is not to be expected that slicer can generate those lines automatically.
But idea is good. I would be satisfied with option to freely draw those lines at bed level plane on my own.
You could do that easily in CAD, no need for slicer complications.
