Each model is "flying" after Slicing with Prusaslicer2.5
[Résolu] Each model is "flying" after Slicing with Prusaslicer2.5
siam
 siam
(@siam)
I have a curious problem since Prusaslicer 2.5 each model I slice has an offset from ca 3 mm from the bed
the model is laying on the bed before slicing
what did i wrong ?
the project is attached here:  model
greets
Andy
Best Answer by Neophyl:
In your start gcode section the final line you have is "g92 e0", that is resetting all your axis to be zero at the current position which is 3mm up.  Change it to "g92 E0" with a capital E and it then looks like it slices correctly.
Publié : 16/09/2022 11:12 am
RE: Each model is "flying" after Slicing with Prusaslicer2.5
Publié : 16/09/2022 12:25 pm
In your picture, at bottom right, there is a fine extension beneath the body.  Your print *is* touching the bed but only at that point. Your code is jumping up from the start before slicing the rest.  See @neophyl's suggestion.
Publié : 16/09/2022 1:23 pm
siam
 siam
(@siam)
Posted by: @neophyl
This solved my issue, thank you!
Publié : 16/09/2022 2:01 pm
