Compensate underextrusion using slicer
dma_k
(@dma_k)
Dear all,
I am using Prusa slicer v2.7.2. On Ender-3 I observe the following underextrusion where seam is located. I have reduced it a bit using "Seam position: Rear", but it is still far from ideal.
Linear advance is off, retract is off (see filament custom G-code).
Can anything else be made, except slowing down the print speed? Thanks for any hint in advance!
This topic was modified 2 years temu by dma_k
Opublikowany : 14/08/2024 1:33 am
Robin
(@robin)
RE: Compensate underextrusion using slicer
This looks like an retraction issue to me. Did you print sucessfully (without this issue) with your settings/printer combination before?
Opublikowany : 14/08/2024 11:07 am
